- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have a paid-for BT hosted site and am trying to protect part of this using .htaccess / .htpasswd. I have placed the password file with encrypted password at public (root) and the .htaccess file in the folder I wish to protect. I do get prompted for username / password when I attempt to access the protected folder but the details entered are not recognised.
The .htaccess file looks like:
AuthUserFile /public/myfolder/protected/.htpasswd
AuthType Basic
AuthName "Protected Folder"
Require valid-user
Any suggestions as to errors in this process would be appreciated.
Bill
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ok, the .htpasswd file can be placed anywhere you like, but the AuthUserFile line in the .htacces file needs to point to the location of the .htpasswd file and not the folder you want to protect (although these may be the same).
the .htaccess file must go in the directory you wish to protect
If you have placed the .htpasswd file into the root then your AuthUserFile line should read:
AuthUserFile /services/webpages/g/o/goweralg.co.uk/.htpasswd
If you have placed the .htpasswd file into the actual directory you want to protect then your AuthUserFile line should read:
AuthUserFile /services/webpages/g/o/goweralg.co.uk/public/myfolder/protected/.htpasswd
Anywhere else and hopefully you get the idea!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have you subscribed to the Advanced / Professional web hosting package with BT?
.htaccess will only work if you have this package.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This is not true houdini.
It is the path to the .htpasswd file that is not right. You need to specify the fulll server path to your websace which you will probably not be aware of
Give me your domain name and I will post the correct path for you.
Also, please confirm where you have placed the .htpassed file as you stated you have placed in in root but your .htaccess file seems to suggest otherwise.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Many thanks
I have just the base hosting package (5 pounds / month) and not the professional (where I could I think protect using the provided management tools).
Domain is www.goweralg.co.uk
I have (initially) put a trial password file at 'public' level where the index.htm for the site is. Using FTP on login I initially see (secure / public / private / logs and cgi-bin). I wish to protect (say) a 'protected' folder found under 'myfolder' under public as below.
AuthType Basic
Require valid-user
Many Thanks
Bill
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Many thanks for a quick and very clear explanation - I am sure I can work things out from here - though there is no way I could have worked out the AuthUserFile path!!
Thanks again
Bill
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Wow Dave that's a very useful post, thanks!
TheOtherOne
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
dear dave,
i followed your directions about the path but had no success. is there anything that I am missing? I have placed the .htpasswd at the root directory and i am using
AuthUserFile /services/webpages/g/o/omltd.com/.htpasswd
on my .htaccess, but I cannot go through the login. the domain is omltd.com
is that right? do I need to enable anything with BT?
thanks in advance for your help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello Tassoss,
The AuthUserFile path should read as follows:
AuthUserFile /services/webpages/o/m/omltd.com/.htpasswd
The webspaces are organised in directories on the server based on the first 2 letters of the domain, which is why yours should be /o/m/omltd.com/ rather than /g/o/omltd.com/
Hope this helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello guys!
Thanks for all the contributions you have done; it helped me in getting closer to the solution. However, after finalising my .htaccess and .htpasswd I am getting some error message.
My .htpasswd is in the root folder and my .htacess code looks like this:
AuthUserFile /services/webpages/c/a/carmelcrest.co.uk/.htpasswd
AuthType Basic
AuthName "Staff Zone"
Require valid-user
