Playstation Network Problems
whitly
Member
When ever I try to connect on to playstation network after 6pm it either takes from 10 mins to 30 mins to connect or sometimes it doesn't.
I'm not the only person to encounter this issue on bt broadband but when another person who had this problem changed providers to sky there problem disappeared.
Is this problem just with bt as it can be very annoying. Or is there a solution to this?
1 REPLY 1
Alun
Master User
Hi whitly,
Can you confirm that you have BT Business Broadband?
Regards,
Alun
BT Business Support Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
