Poor Broadband performance
alan02893
Member
Hi, I've been having poor broadband speeds for some time now. Will take for ever browsing to pages and my VPN connection keeps dropping out. I have had a couple of engineer visits over the last few weeks and had my line replaced a couple of times but have seen no improvement in the service. I have engineer visiting again tomorrow but i'll guess we'll go through the same process again and end up with the same result.
I've pasted in my dsl stats and would appreciate it if someone could have a look and make any suggestions as to what the problem may actually be
DSL DetailsDown Up
Modem Type:Built in modem - ADSL
DSL Line (Wire Pair):Line 1 (inner pair)
Current DSL Connection:
Rate:14103 kbs1150 kbs
Max Rate:14103 kbs1150 kbs
Noise Margin:2.9 dB4.8 dB
Attenuation:39.5 dB21.3 dB
Output Power:20.5 dBm12.2 dBm
Protocol:G.DMT2+ Annex A
Channel:Interleaved
DSLAM Vendor InformationCountry: {46336} Vendor: {IFTN} Specific: {48753 }
ATM PVC:0/38
Rate Cap:14103 kbs
Attenuation @ 300kHz:39.5 dB
Uncanceled Echo:-15.9 dBOk
VCXO Frequency Offset:-6.6 ppmOk
Final Receive Gain:21.4 dBOk
Impulse Noise Comp. Tones:0Ok
Excessive Impulse Noise:0Ok
Traffic Statistics
Bytes Packets Errors %Cells Errors %
IP Traffic
Transmit:26389602836000
Receive:329824033741300
ATM Traffic
Transmit:78025200
Receive:410687600
DSL Link Errors
Collected for 1Day0:41:17
Reset 24-hr int. 15-min int. Last Event
 SinceCurrentCurrentTime Since
ATM
Last Event
Cell Header Errors5132462513449430:00:57
Loss of cell Delineation4976812494849090:01:09
DSL
Link Retrains:20020:33:12
DSL Training Errors:40020:32:51
Training Timeouts:0000:00:00
Loss of Framing Failures:30020:33:12
Loss of Signal Failures:40020:33:12
Loss of Power Failures:0000:00:00
Loss of Margin Failures:139797190:01:10
**bleep**. Seconds w/Errors:112995421090:00:57
**bleep**. Sec. w/Severe Errors:9125446890:01:12
Corrected Blocks:4692897142930390390:00:00
Uncorrectable Blocks:5126032506649400:00:57
DSL Unavailable Seconds:1960020:32:32
9 REPLIES 9
MHC
Guru
That snapshot looks fine - but the problem could be with part of your PC set up or an interference problem on the line which appears then goes ...
Have you checked and corrected any issues with RWIN and MTU settings ?
Run a test and follow advice from:  http://www.dslreports.com/tweaks
Check your line quality by downloading a copy of RouterStats Lite - then run it for 24 hours plotting the SNR and Sync speed with 30 second updates.   Once you have that, is there anything significant at the time when you have teh dropouts?
alan02893
Member
Thanks for that. I'm not sure if it is my laptop as when i connect it to my SKY broadband service at home i do not get these issues. I ran a test and followed the advice recommended in dslreports/tweaks but that hasn't changed anything. I've been running routerstats lite for the last 15 hours or so and can't really see any issue with that, connections speed is consistant at 14000kbps and the SNR fluctuates between 0 db to 3db. one thing that i have noticed is the Internet light on my BT2700HGV goes red every so often.
The engineer is due this morning so i'll wait to see what he suggests.
regards
Alan
ryanjkeen
Member
Hi Alan, my customer is having the same sort of issues. Your not in ST Ives or Huntingdon are you?
alan02893
Member
Hi, I'm afraid not, i'm in Belfast. Been like this for quite some time.
regards
Alan
MHC
Guru
Have a look at the "Training History"
http://192.168.xxx.xxx/xslt?PAGE=C_5_3     you need the IP address of your router where I have put 192.168.xxx.xxx
That page gives the last 20 sync related events and may hold a clue.
From your overall comments you can rule out your PC ... (people often blame the line/service when the fault is on their PC).
alan02893
Member
Thanks For that. Engineer arrived yesterday did some tests and determined that there was a fault in the exhange as the line wasn't syncing correctly. He did a 'lift and shift' and my profile was reset. So far so good, had a brief period of problems this afternoon but much better tahn before.
regards
Alan
MHC
Guru
Alan,
In your original post there are two lines:
I no longer run a 2700 on ADSL - moved to VDSL so cannot see those here.    What does teh text actually say that is so bad that it gets censored here?
You may need to type in the form A#B#C#D#E   ...
And just keep looking at the log and see if you lose sync or resync very often.
alan02893
Member
Hi,
The *bleep* should say cumlative
regards
Alan
MHC
Guru
I presume that your post should say:    cumulative
A great censor!    But I wonder why it did it to the original but not when typed here.   Or was it:
**bleep**.Seconds w/errors
edit to add:
Oh dear - I now see why and definitely a problem with the way the censor works!
