Observations
Case Conclusion
Global conclusions
This happens everywhere no matter what line you use.
I think it's best to either look for another plan that might work pretty well for you. Because you don't want to pay for a service that you are not fully taking advantage of. I understand how this works and we really can't blame the provider.
Actually I disagee it doesn't happen everywhere and it certainly shouldn't happen when the copper line measures properly. We have around 10 broadband connections to various sites and they mostly work rather well.
Once it has gone from the port into the DSLAM then it is simply a glorified layered IP network. Getting the traffic managemnt and prioritisation wrong in that is pretty silly, as it is well known how to do it. Lets face is VDSL isn't cutting edge it is, politely, a very mature technology.
My suspision is that the assigned bandwith to the connection is misset at 40Mb/s and for a 40/10 that means that once the reserved frequenceis are taken off between voice and upstream the downstream is left with limited bandwidth. That is in all likelyhood a config error and pretty simple to sort it should of course be set to 50Mb/s. The maddening thing is that nobody has the power to investigate what is going on from end to end.
Hi,
If you want to contact me directly I'd be happy to follow up on this issue with the Infinity Fibre team and try and get some answers for you.
karen@325consultancy.com
Best regards,
Well we have had another engineer come out and go through all the copper side gear and confirm that it is all 100% and he can't understand what is going on either. Nice guy, very, very, very thorough.
The nub of the issue is that BT blame OFCOM for preventing faults being handed between OpenReach and Wholesale. I don't think OFCOM intend that at all and it is being used as a convenient excuse to shelve issues of marginal functionality.
As Wholesale own the Port - DSLAM in the big green cabinet the engineer needs their say so to start tinkering with it.
However, the engineer can't get a number to speak to Wholesale whilst onsite: he (the nice engineer) tried but no dice.
Where there is a hard fault and the OpenReach Engineer has confirmed it is should go through an automated triage. Along the lines of we have done all our tests it isn't at spec therefore a deeper investigation is required.
At the moment the only way it gets triaged is if you start complaining very very loudly.
OFCOM - don't get me started! Their rules really make things difficult and BT get their knuckles rapped if they try to bend the rules. It is almost certainly totally true.
I had a fault, and it was obviously ORs responsibility. Spoke to Business faults, who had to speak to their Point of Contact, who then spoke to the OR Point of Contact who spoke to the repair team in OR who spoke to the specific middle manager ... How many extra layers and delays in that? Too many ...
OFCOM put rules and regulations in which attempt to make it "fairer" but ultimately the end user or customer pays.
Another example: I needed a fibre feed from an overseas site into a UK location. BT could break out and give us a feed. But NO, OFCOM required it to be run all the way to London, turned round and run all te way back to the location where both we and BT had facilities. The extra cost was measurable in tens of thousands of pounds per year!
Well partial sucess
One of the enigneers who had previosuly been out appeared and said this is riduculous. The sync speed and the throughput doesn't match.
So he had a bit of a brainwave and said why doesn't he measure the throughput at the cabinet end. In this instance not to difficult as the cabinet is bolted to the wall of the excahange. So off he goes with the router and the modem and come back saying it makes hardly any measurable difference is the moden is connected to the cabinet or in your office "the problem is in the cabinet." He also disconnected the exchange end so he was testing just the DSLAM which eliminates the possibiltiy of dodgy filters spewing out the wrong frequencies etc.
Armed with this info he then persudes the power that be in Wholesale to do a lift and shift: this of course goes wrong and "gets stuck." Not his fault but after all this it did feel like the last straw.
However, the good news was when it was "unstuck" two days later 37/8 suddenly appeared. I'm perferctly prepared to accept that this is decent performance.
However, as another engineer pointed out, this doesn't mean it was a port fault it could have been to do with the firmware that is flashed to the port to enable the service.
Now all we need to do is to get this performance done on the other line........
Moral of the story if your sync speed is good and the troughput is dreadful don't accept "it is the copper/aluminum wire BS" becasue BS is exactly what it is.
Really if the sync is good and the throughput is awful then the port should be reflashed as a matter of course. It is a zero cost job that can be done from a remote computer and but it doesn't appear as a solution on the fault handling protocol.
Hmme
Well now our other number is down totally.
Apparently BT decided to do some work overnight without telling us and it hasn't quite worked out.
Great.
Except that the VOIP system that rerouts the emergency site contacts runs via this Infinity line. And yes there is a backup but if somebody helpfully removes one service then it is running solo.
If they had bother to tell us then we could have moved one RJ45 and been prepared for this.
8/10 people I deal with at BT are very profesional and try desperately to help but they are up against a system that forces them to do, well nothing useful. They know and acknowledge that there is a real problem here that can be fixed.
This isn't just crazy it is sapping huge amounts of productivity from UK businesses. The big question is why are BT still allowed to get away with this as it isn't a customer service isssue it is a pure serivce provision (lack of) issue.
