Hi,
We have tried to open a port in the router for SQL server access, however it is showing the following in the log:
15:13:36, 11 Feb.
:This Rule has been applied successfully: [id:152, InternalClient: 192.168.1.65, External Ports:(5000,5000), Internal Ports: (0,0), Protocol: TCP/UDP]
15:13:36, 11 Feb.
:Adding port mapping rule by User
15:13:36, 11 Feb.
:Updating port mapping rule (152) by User
15:13:36, 11 Feb.
:Deleting port mapping rule (152) by User
15:13:36, 11 Feb.
We have read some other threads that suggest turning uPNP off and trying again but we are having no luck.
Also, we have tried using the standard port 1433 but are having the same results in the logs.
