I have swapped all of my products to one of the new layouts. However after changing I noticed a major problem which is that the price doesn't show up anywhere on the page!!! Also, the delivery period appears in the top-left not once but twice.
I'm hoping these are just bugs and the pages aren't supposed to be like this. Does anyone know if these are going to be fixed soon?
Wow, that's a big problem - no prices displayed. I'm using the new product page layouts and my prices are displayed OK.
If I were you I would go back to one of the old layouts whilst I tested the new ones. You could create a test product and product type in order to do some tests.
One suggestion - are your prices the same colour as your background?
Hi,
I have set the layout to reflect the new product layout but how do you apply this to ALL products listed?? We have the majority in the old format and a random selection in the new format.
KMC
You should change the layout for all "Product types" that you are using.
Thanks all sorted!
No it's not a font colour problem, the prices just weren't there. A little bizarre that they are for some people but not for me! I contacted BT who told me it was a technical problem that would be fixed with the next update, and in the meantime I should just go back to using an old layout. The old layouts will disappear with the next update though so I do hope this'll be fixed by then, can't have a shop with no prices showing!
