Hi
Am failing miserably trying to set up my e-mails on my new Iphone 5. I have a business btconnect e-m account. It was upgraded to 365 a while ago. Access it on my pc with outlook - no problems. Access via my iPad - no problems.
I have tried following Burkem5's 'set up with screen shots' posting above - to the best of my knowledge exactly; but when i click 'done' it simply hangs in 'verifying'. only way out is to power down.
A couple of points that might be relevant.
a) I had the pc & iPad access in place before the 365 upgrade, whereas i've never tried to access emails on a phone before.
b) my screen looks a little different to the screen shots - the '365' button never appears in the top left corner; and there is is no 'advanced' settings button visible - like on the iPad.
Thanks in advance if anyone can help me solve this?
John
Solved! Go to Solution.
Hi JMS
If you go to this forum topic it explains how to setup BT email addresses on an Iphone/Ipad
I hope this helps
Mark
Hi JMS
I hope this helps
Mark
