Hi
I have had my website with bt for 3 years and have never been able to adjust the colour of font or vertical horizontal option for menu toolbar. I know bt have now allowed for this to be done in the easysitewizard pro, which is great.
My problem is that I have sub links to each page and when you change the menu bar from vertical to horizontal, the sub pages also go horizontal. I want my menu bar to be horizontal and the sub categories to show underneath.
Does anyone now if this is a common problem or does anyone know how I do this.
Hi Amor,
If you can supply your domain name or webpage, our users will be able to have a look and maybe offer some advice with this.
Kind Regards
Fiona
BT Business Forum Moderator
Hi Amor,
Have you managed to resolve this issue?
Kind Regards
Fiona
Hi I know it has been a few months since I asked this question regarding problems with menu bar. The Menu bar editor allows you to have the menu bar horizontal, which is great but the sub pages also go horizontal, which is not ideal. So if you had a page title for example called Designs and you wanted to list a few different categories unde that page name, the sub page categories will not go underneath they go across. I have not seen this before with other websites and normally any sub page should follow underneath a page name.
any advice much appreciated
Currently this option is not available in the Easy Site Wizard menu editor but if I understand correctly the programmers are looking at this option in future releases. In the meantime I believe you can edit the code for the CSS to accomplish this but coding is a bit over my head.
Hi are there any updates yet regarding having the toolbar at top of the page with sub-titles underneath each heading?
Most other web hosts have this option where you click on the toolbar at the top and all subheadings are underneath and not horizontal. Also will there be an option to have a tool bar at the top and also one at the side.
many thanks
If you have any idea about CSS or HTML, you will be able to work on that on your own.
