Problems with outlook.com not picking up my btconnect emails since 10th Jan (Upgrade related?)
Corneloues
Member
Since the 19th of Jan, outlook.com has struggled to pick up my btconnect e-mail.
I get the occasional message come through, but everytime I go in to outlook.com and check my other account settings I always get the following popup:
"4:03 PM We couldn't get your messages: There was a problem connecting to the other server. If you've been seeing this message for a while, consider checking your account settings or contacting your other email service."
I have nearly a 400 email backlog. I know the settings in outlook.com are correct as I use the same details to access the webmail!
Wondering whether this is upgrade related...
Cheers,
Roy
1 ACCEPTED SOLUTION
Accepted Solutions
Corneloues
Member
I have found the problem.
If outlook.com has an issue with one of the e-mails, the POP3 collector fails and then will refuse to download any other e-mail.
My solution (using Outlook 2010):
  • Create a new mail account using my POP3 account details
  • Exclude the account from the main send/receive group
  • Download all the e-mail from the POP3 account to the new local Outlook file
  • Once downloaded, move the e-mail back to the outlook.com mail file
Once the problem e-mail has been downloaded outside of the outlook.com connector, it will resume service as normal.
There is obviously work needed to be done on this collector by Microsoft!
I hope this helps others.
Cheers,
Roy
View solution in original post
5 REPLIES 5
adrianc
Master User
There is a good chance it is upgrade related - if your account has been migrated then you'll need to change the settings in outlook.com to point to the new server. If it's not been migrated, double check that outook.com is still pointed to mail.btconnect.com rather than smtp.outlook.com.
Hope that helps,
Adrian
Corneloues
Member
Adrian,
One would assume if I had ben upgraded then I wouldnit be able to log in to the old OWA web mail client.
If I login to business.bt.com with my @btconnect.com email addy and password, I still end up at OWA.
Cheers,
Roy
adrianc
Master User
Hi,
Actually, you will still be able to log into the old webmail even after you are migrated - I have an account that has been migrated but I can still log on to email.btconnect.com. I am guessing this is in case there are any messages that don't get copied over to the new service.
When you log in to the self-care pages, do you get the "Manage Mailboxes" link, or a button that says "Email Summary" - if the former then the account is, as you said, not migrated. If the latter, then it has been migrated.
BTW - as you probably noticed, I had a brain-fart in my previous post. The incoming servers are pop3.btconnect.com for non-migrated and pop.outlook.com for migrated accounts.
Adrian
Corneloues
Member
Yep, I still; get the "Manage mailboxes" link, so not migrated.
Still can't understand why outlook.com is not picking up my mail!
Cheers,
Roy
Corneloues
Member
Cheers,
Roy
