Prompted to rest paswword, now no access.
grant992
Member
I was prompted to change expiring email password. This box was in top left corner AFTER login (btconnect 365). Having done so, I have only managed to access emails twice after countless attempts. Im repeated told its the wrong password!
Anybody able to help.
Thank you.
1 ACCEPTED SOLUTION
Accepted Solutions
Burkem5
Guru
HI Grant922,
This is a known issue with Microsoft and we have them investigating this as we speak, we aim to clear this as soon as possible.
In the mean time c an you please contact us or go through myoffice.bt.com > Service > Email summary  to reset this.
Burkem5
View solution in original post
4 REPLIES 4
Burkem5
Guru
HI Grant922,
Burkem5
grant992
Member
Burkem5
Thank you. Will give it a try.
grant992
Member
Burkem, thank you.
Went Via business help, and I got the password reset during a live chat.
I was told the prompt to update the password is a Microsoft issue and to ignore it. I should be gone with a few days.
The sort worked well, waited 2mins for an operator, and it took 10mins to sort. It is however a bit disconcerting giving all your details away to someone on the end of a keypad!
Thanks again
Burkem5
Guru
Hi Grant992
Its great to hear thats been fiixed,  I work on the livechat desk myself so its always great see people happy with the livechat service.
Burkem5
