RSS news feed
joy
Member
How can I embed a php Code for an RSS news feed on my website that I created using the Easysite Wizard Pro?
Many thanks,
joy
6 REPLIES 6
BLWRAVE
BT Partner
BT Partner
Hello To add your php code for your RSS news feed in Easy Site Wizard you can use the "Advanced options" botton and edit Html code added the code into the page where you want it.
joy
Member
Hi  BLWRAVE, Thanks for your response. I clicked 'edit html source' and pasted the code but nothing happened. Is there something else I should be doing?
thanks. looking forward to your help!
duskjome
BT Partner
BT Partner
There should also be an option to "Enable RSS" in your easy site wizard pro in the sites section in the Details box, has this been enabled as well?
dave
Guru
You cant't paste php code into HTML files as php needs to be run as a separate file with a .php extension.
Enable the EasySiteWizard Pro's own RSS function, and you will then be given the option to update the RSS feed every time you publish.
joy
Member
Hi duskjome,
yes the Enable RSS option has been checked, but I need the kind that enables my site to receive RSS feed from another site. Does this do that?
Thanks for your help.
joy
Member
Hi Dave,
Thanks for your response. Is there a way I can get rss feeds from another website to mine? I mean an easy enough way that is sort of fool proof?
Thank you for your help
Joy
