I think with the BT Business Hub, the technical helpdesk (0845 600 70 20 Opt 2) can help with setting up the router to allow remote access through it to another device on your network (port forwarding). They can definitely help with setting up static IPs.
As far as I know you cannot access the router itself remotely though.......
All the best with the configuration. I would give the information I have on how to set up the 2700 (for static IPs and to allow a remote connection through it) but I think it's better you go through the technical helpdesk to get it for purposes of liability.
I look outside and it's,
D.A.R.K
