Re: BT Versatility BBM+ and V-IP Featurephones
Fiona
Grand Guru
Hi RichW and Smartmt
I have checked with the Versatility team and they have said this isn’t a common problem.  It has only been seen occasionally and only ever in the circumstances described in my previous reply.
Unfortunately It isn’t possible to offer any other answer to what is causing the issue without carrying out some diagnostics. To do this you would either need to contact BT Versatility if you have a maintenance contract with them, or contact your maintaner if this is with someone else.
I'm really sorry I can't offer any more advice with this, but I hope that you do get it resolved soon.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
0 REPLIES 0
