Re: BT Versatility arghhhhh!
James
Master User
You've probably worked it out by now (!) but for anyone else with the same issue:
- Ensure that the group you have added your extension to is the group that the incoming lines are set to ring on, as there are 20 groups on the system.
- Make sure that there are no diverts set on the group and that auto attendant is not switched on.
- Make sure that you can receive internal calls on the extension, so make sure that nothing like do not disturb is set.
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
Thank you.
0 REPLIES 0
