Re: Redirecting domain
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
I need to change the www record in my advanced domain settings in order for the domain redirect to work. It's greyed-out at the moment. Please can a moderator change it for me?
I want to forward:
danismanltd.co.uk
to:
http://home.btconnect.com/danismanltd/
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It seems like you do not have a compatible hosting package to fully support DNS management. If you do i suggest contacting BT technical support to resolve your issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
To change where you domain points you would need to configure your zone setting. There is information online to help you with the zone settings in the Domains Centre.
From your post it looks like you are trying to change the 'www' record to point your domain to your free webspace provided by BT Business. There is help online and information on frame and url forwarding that may help you with this.
If the zone settings are grayed out, or will not let you change them you will need to Contact the Domain Team.
I hope this helps
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
