Re: Versatility: lock phones on weekends but with allow for authorised users
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi Ihphone,
1.LCR will make no difference to the system speed dials, I can only assume they are not being used correctly. System speed dials will be used by pressing "Directory" > "System Speed Dial" > and selecting the speed dial from the list.
2.You must have digits to replace with otherwise it will not remove the digits you have dialled. E.g. If you put an LCR code of "159" in the system, but have no digits to replace, the whole 159 is send to the line in front of the number you have dialled, therefore getting number not recognized. When you enter a digit to replace with, the digits you actually dialled will be replaced with this. E.g. "1590" replace with "0", dialling "1590" will replace the "1590" you have dialled with a "0" to the line followed by the rest of the digits you have dialled.
3.Again in reference to system speed dial override, this will only work if the system speed dials are actually accessed from the system by using either the short codes starting with "8" (i.e. 8001 etc) or as detailed in point 1 above. Just manually dialling a number that is in the system speed dials will not work.
Hope this helps
Tracey
BT Forum Modertor
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
