Re: Versatility: lock phones on weekends but with allow for authorised users
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello Tracey,
Thanks for the explanation in your pt 2. That's clear now.
For points 1 and 3: Unfortunately my LCR/speed dial doesn't seem to function in the way you describe.
This is what I do:
# I put the whole system into "LCR On" (Program -> System Programming -> Lines -> LCR Codes -> LCR On)
# Next, I dial a number manually, e.g. 07987etc. Result: I get an error tone and the message "line not equipped", which shows that the LCR setting is in effect.
# Next, I try the speed dial (both Directory -> System Speed Dial and then I select something, or I dial 8xxx). Result: I get the same effect as dialling a number manually. That is, I also get an error tone and the message "line not equipped".
On further reflection, I would have thought that, in a 'usual' situation, the speed dial must also be subject to LCR, otherwise anyone using the speed dial (common in many offices!) would not get the benefit of the LCR...
What am I doing differently from your example? Thanks!
-terry
This is what I do:
-terry
0
Kudos
0 REPLIES 0
