Recently a tech has helped with my website. Since then I cannot publish it wont accept my password.
west2
Member
please help!
Re: The ticket # 2483363
Thought I would change my sites password in my services  on the FrontPage
extensions, waited for ages after pressing next, but nothing happened
after half an hour.
I then managed to change the password
pressed next and received this message
Starting users, port: 80, web: "/".
Created: unknown
Version: unknown
Error: The server administration programs and the server extensions on
the web server are not compatible. The server is too old to use with
this administration program.
I still cannot update my web site
3 REPLIES 3
duskjome
BT Partner
BT Partner
Assuming you are not using sub webs in your Frontpage install it is usually a good solution to uninstall the server extensions and reinstall them again with the password you want.
You can do this with your Frontpage Manager, usually the top option under Site Builders, choose the "uninstall" tab and then hit next until complete and then choose the "install" tab and add the password you want and hit next until complete. It might take a few minutes but it shouldn't take longer than maybe five minutes.
west2
Member
Th issue with the password has now been solved thank you
But I have now received a message back from the techs
We kindly advise you to point your domain to our name servers:
> ns1.carrierzone.com
> ns2.carrierzone.com
> ns3.carrierzone.com
> ns4.carrierzone.com
On looking my domain name up on whois I get this
 Registrar:
        Register.com Inc t/a British Telecom [Tag = BTNAMES]
        URL: http://www.btconnect.com
Name servers:
        dns01.gpn.register.com
        dns02.gpn.register.com
        dns03.gpn.register.com
        dns04.gpn.register.com
        dns05.gpn.register.com
How do I change these, I have been with b.t for over a year, why have the name servers changed.
I wondered why my web site is dead.
Has everybodies name server changed?
duskjome
BT Partner
BT Partner
As far as I know Bt hasn't changed their nameservers, and I did a quick dns lookup as well and it looks like you don't have a zone file provisioned on those name servers. Which is a complex way of saying if you switch to those name servers your site will go down. From what I can see your nameservers are correct the way they are so I wouldn't mess with them if I were in your shoes.
