SMTP Failure - BT Office 365 Incoming OK
pinkhost123
Member
Please help - My Macbook Pro has been using smtp.outlook.com for my btconnect mail account perfectly from migration point but has just stopped working for outgoing mail. My Ipad works fine on the same router so cannot understand why it will not send. I have even downloaded outlook for mac but get the same problem will connect for pop incoming only
I have also tried pod51017.outlook.com from the options space within webmail still to no avail...
1 REPLY 1
Burkem5
Guru
Hi Pinkhost123
Can you double check you are also using these settings for the outgoing server ?
Server - smtp.outlook.com
port – 587
connection type – tls
make sure the outgoing server requires authentication and authenticate with the same details as the incoming server
If so c an you see if you are using a HUB3 ? That's a black router with blue lights
If that is the case please set the DNS
You can do this by clicking on the airport (wireless) icon in the top right corner then going to preferences and then DNS
click the plus button and then add what ever servers you want to use.
I tend to stick with googles
8.8.8.8
and
8.8.4.4
Once you have saved this shut down your mail client and then reopen that.
If this does not work I suggest you contact us
I hope this helps
