I have a software application that uses Chilkat to send emails and has been working fine for ages through BT. In the last week it has stopped and now everytime it tries to send a message Chilkat produces the following (partial) error log showing the conversation (suitably redacted):
SmtpConnect:
SmtpHost: smtp.btconnect.com
SmtpPort: 25
SmtpUsername: enquiries@xxxxxxxxxxxxxxxx.co.uk
SmtpSsl: 0
StartTLS: 0
Need new SMTP connection
checkForExistingConnection: Elapsed time: 0 millisec
SMTP_Connect:
Connecting to SMTP server smtp.btconnect.com:25
smtp_host: smtp.btconnect.com
smtp_port: 25
smtp_user: enquiries@xxxxxxxxxxxxxxxxxx.co.uk
ConnectTimeoutMs_1: 30000
calling ConnectSocket2
IPV6 enabled connect with NO heartbeat.
connectingTo: smtp.btconnect.com
Resolving domain name (IPV4) via gethostbyname
GetHostByNameHB_ipv4: Elapsed time: 62 millisec
myIP_1: 192.168.1.64
myPort_1: 60577
connect successful (1)
socketConnect: Elapsed time: 78 millisec
InitialResponse: 220 mail.btconnect.com ESMTP
initialResponse: Elapsed time: 31 millisec
sendingHello: EHLO RB-Counter
sendEhlo: Elapsed time: 0 millisec
helloResponse: 250-mail.btconnect.com Hello RB-Counter
250-8BITMIME
250-SIZE 52428800
250-ETRN
250-DSN
250 PIPELINING
helloResponse: Elapsed time: 15 millisec
This SMTP server did not list authentication methods.
Defaulting to LOGIN authentication method.
login_method: LOGIN
535 5.7.3 Authentication unsuccessful
Failed to get response to login password
ConnectionLog:
EHLO RB-Counter
The smtp user name has been tried with and without the domain name listed (it worked fine without).
The password is correct as I can connect to the BT server using TelNet on port 25. Also using Outlook it works fine.
Client is a Windows 7 PC running in a workgroup.
From what I can tell BT is telling the system that it is trying to relay however I repeat this was working fine up to a week ago so wonder if something has again changed at BT which they seem to do every 6 months without telling us.
I can change Chilkat to use different ports and/or use TLS if someone thinks that may help?
Appreciate any suggestions.
Many thanks
John
Solved! Go to Solution.
OK solved this.
As I mentioned for months this has been working OK. The solution was to ensure the login id/password used for "smptlogin=" and "Smtppassword=" was for the BT account itself given when it was first set-up.
Up until now had been using the prefix of the email address (before the @) and the password for that account. But the error message, although not clear, was actually stating could not connect to the account any longer. BT would not admit they had changed anything but effectively they were no longer recognising the email address/password. This was despite it working perfectly in Outlook and is listed in the list of allowed relays.
So happy bunny once more. Hope this helps anyone else using Chilkat - an excellent piece of software for developers.
John
Is this the first time you have this type of problem? I am about to use Chilkat and good to see this post of yours. I guess I have to wait until this one has been resolved. Have you checked Chilkat about it?
OK solved this.
John
