STATIC IP AND COMPUTER SET UP
antoine
Member
Hi all
It is a kind of follow up question of my post re FTP and Static address but a bit different hence the new post.
I have ordered the static IP and the order wil take up to 24 hours to compete.
Once I reboot the router I should be able to see the new IP address/subnet mask/default gateway and the DNS.
As for my laptops (we have 3 of them) do I need to go into the wreless adpater porperty for the TCP/IPv4 and enter the IP address and DNS manually or can I keep the "obtain IP address automatically" option.
If manual  willl all three laptop need to have a different IP address (last digit of the string) with the same subnet anf default gateway?
Apologies if this is a basic question...
Thanks for your help
Anton
2 REPLIES 2
alastair
Grand Guru
you need need to change anything on the laptops.
the only thing you will require is "port forwarding"
there are guides on this in the broadband and internet section
=~~= All Glory to the Hypnotoad! =~~=
James
Master User
Hi antoine, go to Help & support and search for 'port forwarding' using the search field within the green box. I would point you in the direction of the relevant article but I'm not sure what router you use.
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
Thank you.
