Sender address rejected: "invalid" TLD in MX record
indcraig
Member
Reporting-MTA: dns;bigfish.com
Received-From-MTA: dns;mail191-db8-R.bigfish.com
Arrival-Date: Tue, 19 Mar 2013 10:30:03 +0000
Final-Recipient: rfc822;[email protected]  (changed email to protect email)
Action: failed
Status: 5.7.1
Diagnostic-Code: smtp;554 5.7.1 <[email protected]>: Sender address rejected: "invalid" TLD in MX record
Remote-MTA: dns;mdfmta006.tch.inty.net
http://forum.demon.net/topic/undeliverable-re
After reading through the above and a couple of other recent forum/posts regarding this issue I thought this would be the most apt place to find a solution.
I have only been made aware of this pre-existing problem by staff today. They informed me that since 01/02/13 they have had their email changed to 365 and this this upgrade they have started recieving MAILER-DAEMON errors from clients whom they never had any problems with before.
I've included the log of one of these failures, hopefully someone can assist. I can provide any information which may assist.
regards,
indCraig
5 REPLIES 5
Plumly
Grand Master
Hi indCraig,
You probably got an MX record on your domain called,
Record MX
Priority 50
Value msxxxxxxx.msv1.invalid
If you remove this entry from your DNS Management page, this NDR will no longer happen,
Plumly
indcraig
Member
Hi plumly, I'll check this solution next time I'm in work. Thanks for the post.
Plumly
Grand Master
no Worries Craig,
did you manage to test this,
Plumly
indcraig
Member
not yet, I'm the IT person at quite a few small businesses and this particular one I've not been back into yet. Promise to re-visit the thread once I've been in.
indcraig
Member
it seems like the problem was on BT's side. I was in this workplace last week and the problem had been resolved by BT tech staff. Staff mentioned something about the daemon failure message being switched to webmaster..... I was only in for 2 hours to fix problematic computer.
