Static Router IP with 5 static IP addresses
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have a Tomato USB Router connected and working well. I also have 5 static IPs that are routing fine to internal servers on my LAN. The problem I have is that PC's on my LAN are going out on the dynamic IP address that the modem provides - and this changes.
I spoke with BT and they said if I downgraded to 1 static IP it would work but with 5 I have to use the dynamic one, but they said for some (unsupported) routers you can set it to go out as one of the 5 static but I can't see where I'd do that...
Does anyone know how to configure Tomato to present itself as one of the static IP addresses externally?
0
Kudos
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You need to do Port Forward or NAT here. You only need one static public IP. You can check if your router supports this.
0
Kudos
