URGENT HELP REQUIRED
Danny_Evo
Member
Hi
My name is Daniel Evans and I purchased the following domain from you www.dannyevo.co.uk.
I have built a site on Wix.com. As they are not a domain name host i need my domain dannyevo.co.uk to point to their site at the following IP: 216.139.213.144
I have tried to change it myself in the manage domain section but it is locked out.
Hope you can help thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Fiona
Grand Guru
Hi
For changing your Zone Settings please see the following help and support file. Please note that settings associated with your primary domain name are disabled for security reasons. Please contact the helpdesk  and select 'Domans & Hosting' , then select 'DNS A-Records repoint'  and finally select 'email' to fill out a webform and have the domain name configured.
I hope this helps.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
View solution in original post
2 REPLIES 2
Fiona
Grand Guru
Hi
I hope this helps.
Kind Regards
Fiona
Danny_Evo
Member
Hi Fiona
Thanks very much this was what i needed to know
Thanks Danny
