Hi there,
I have a problem, and i dont understand why it even is there.
I have created a homepage for the site: http://www.steelandjelly.co.uk and while publishing it, a messages tells me its to be found under http://steelandjelly.co.uk.c31.sitepreviewer.com ? So i go into domain forwarding, and want to forward the frame from http://steelandjelly.co.uk.c31.sitepreviewer.com to http://www.steelandjelly.co.uk, but this is not possible because of some record?
Please help.
/Ann
thanks for you reply . the hosting is done by bt would you know what number to ring or dept to contact ?
thanks
ANN
Fill in the form avalable on this link and someone should be able to sort it for you farily easily.
