Hi there,
Does this problem occur after or before you log into the account? Does an error message come up when you access the website?
Rgds,
Steph
It happens if I am logged in or out. In the botton L/h corner it says connecting to site 193 173 148 208, after hanging like that for a while an error meesage comes up very very briefly, I think it says res//eframe plus other things also in the message dll error but it is so brief I cannot read it all.
Jenny
Hi Steph,
The error message I am getting is res://ieframe.dll/dnserror.htm
Jenny
Couple of questions first, how are you setup? Do you use a proxy? Do you use SBS or Server 2003?
Try this:
Go to the Start menu then run, in the run box type cmd and click okay, it should bring up a black window. In this window type ipconfig /flushdns then hit enter. See if it works now.
If not go back to the black window and type nslookup and hit enter this will bring up a > prompt, here type tomtom.com make a note of the information posted now type server 208.67.222.222 then hit enter and type tomtom.com again make a not of this information also and type exit then hit enter.
If its still not working post this information here please.
Hi,
I have the same problem accessing http://www.oracle.com
I followed the steps on the last poster but that didn't resolve anything. Here's the nslookup info I got:
> oracle.com
Server: home
Address: 192.168.1.254
Non-authoritative answer:
Address: 141.146.8.66
Default server: resolver1.opendns.com
Address: 208.67.222.222
> oracle.com
Server: resolver1.opendns.com
Address: 205.67.222.222
Address: 208.69.34.132
If anyone has any clue, I'd be glad to hear it. We have a local SBS 2003 running but it's only used for email, we're not filtering traffic in and out of the office from there. We run on a BT2700HGV Hub.
Thanks if anyone can help
Does http://141.146.8.66/ work?
Were those tests done from a client or the SBS server?
I take it you've tried from different machines?
Could you post an ipconfig /all and a tracert 141.146.8.66 if you still can't get to the website.
No, I'm afraid not...
On the client but I've done similar tests on the server and still didn't get any joy
Windows IP Configuration
Host Name . . . . . . . . . . . . : JLPC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : gateway.2wire.net
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : gateway.2wire.net
Description . . . . . . . . . . . : Intel(R) 82562V 10/100 Network Connection
Physical Address. . . . . . . . . : 00-19-D1-50-92-BD
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.69
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 192.168.1.254
Lease Obtained. . . . . . . . . . : 13 August 2008 09:10:35
Lease Expires . . . . . . . . . . : 14 August 2008 09:10:35
Tracing route to bigip-otn-portal.oracle.com [141.146.8.66]
over a maximum of 30 hops:
1 2 ms 1 ms 1 ms home [192.168.1.254]
2 187 ms 348 ms 129 ms btdhg565-hg1.ealing.broadband.bt.net [217.47.197.72]
3 388 ms 500 ms 443 ms 217.47.197.2
4 68 ms 80 ms 66 ms 217.47.197.110
5 65 ms 58 ms 67 ms 217.47.219.162
6 107 ms 85 ms 97 ms 217.41.168.29
7 256 ms 287 ms 305 ms 217.41.168.65
8 320 ms 311 ms 346 ms 217.41.168.122
9 406 ms 451 ms 507 ms 217.41.168.42
10 575 ms 622 ms 640 ms 217.47.202.241
11 504 ms 618 ms 692 ms core1-pos0-7-0-6.ealing.ukcore.bt.net [194.72.17.105]
12 574 ms 572 ms 417 ms transit2-gig7-0-0.ealing.ukcore.bt.net [62.6.200.118]
13 101 ms 101 ms 124 ms t2c2-ge14-0-0.uk-eal.eu.bt.net [166.49.168.57]
14 748 ms 129 ms 194 ms 195.50.91.153
15 362 ms 329 ms 362 ms ae-31-55.ebr1.London2.Level3.net [4.68.117.158]
16 459 ms 408 ms 474 ms ae-1-100.ebr2.London2.Level3.net [4.69.132.122]
17 71 ms 80 ms 70 ms ae-2.ebr1.London1.Level3.net [4.69.132.146]
18 163 ms 147 ms 66 ms ae-1-100.ebr2.London1.Level3.net [4.69.132.118]
19 149 ms 134 ms 157 ms ae-41.ebr1.NewYork1.Level3.net [4.69.137.66]
20 140 ms 142 ms 140 ms ae-91-91.csw4.NewYork1.Level3.net [4.69.134.78]
21 173 ms 141 ms 173 ms ae-93-93.ebr3.NewYork1.Level3.net [4.69.134.109]
22 167 ms 166 ms 175 ms ae-72-72.csw2.Dallas1.Level3.net [4.69.136.142]
23 164 ms 176 ms 175 ms ae-72-72.csw2.Dallas1.Level3.net [4.69.136.142]
24 184 ms 175 ms 164 ms ae-21-79.car1.Dallas1.Level3.net [4.68.19.67]
25 177 ms 177 ms 172 ms ORACLE-CORP.car1.Dallas1.Level3.net [4.71.196.110]
26 185 ms 176 ms 174 ms ora-141-146-3-31.oracle.com [141.146.3.31]
27 539 ms 714 ms 728 ms bigip-otn-portal.oracle.com [141.146.8.66]
Trace complete.
And That's what I don't get, I can ping and tracert without any problem, but I just can't seem to get the website to show up it's weird.
Thanks for the help 🙂
Okay what browser you using, if its IE7 try it without add-ons.
try to telnet to the site and do a head or get request and see what happens then:
telnet oracle.com 80 [enter]
HEAD / HTTP/1.1 [enter] [enter]
A successful reponse will look something like this, ignore the error its for something unrelated:
HTTP/1.1 400 Bad Request
Set-Cookie: BIGipServerwww_prod_pool=2249036429.24862.0000; expires=Wed, 13-Aug-2008 15:26:14 GMT; path=/
Date: Wed, 13 Aug 2008 15:21:14 GMT
Server: OracleAS-Web-Cache-10g/10.1.2.2.1
Content-Type: text/html
<HTML><HEAD><TITLE>Invalid Host Specified</TITLE></HEAD>
<BODY>The request did not specify a valid virtual host.</BODY></HTML>
Two other things to try, start into safe mode with networking and check the router to see if some sort of access restriction has been applied.
Let me know if any of this works.
I've done tests in FF3, IE7, Opera 9.5, Safari 3.1, I even booted the machine with Knoppix to work out if it wasn't a zonealarm thing or something but I didn't get more joy with IceWeasel and Konqueror...
My HTTP request on oracle's telnet gave pretty much the same as yours, except for the html markup:
Set-Cookie: BIGipServerwww_prod_pool=2198704781.24862.0000; expires=Wed, 13-Aug-2008 15:38:06 GMT; path=/
Date: Wed, 13 Aug 2008 15:33:07 GMT
As for the router, I've tried to turn it upside down but the firewall on this type of hub isn't exactly great to configure. There's nowhere I can see that some restrictions are used. I'm basically the one setting up the hub so I can change things if required, provided I can work out how. I've set up Parental Controls on some machines but not on others and either way even by explicitely adding oracle.com in the list of authorised websites, it still has issues. Besides, it's not giving me a 500 or 404 error, it does attempt to connect but it looks as if mostdata packets are being dropped as it tries to pass into out office network.
I'm starting to wonder if that hub hasn't got any issues somehow.
Cheers...
