Unable to access a website
croxlea
Member
Can anyone tell me why I cannot access www.tomtom.com, I do not have a problem with any other site.
14 REPLIES 14
Kirok
Master User
See the telnet via port 80 was simulating a web-brower so if its a block of some sort it would have to be header based but if your trying it from more than one computer then its unlikely a browser misconfig, group policy would be the other option but only email is running from the SBS server
All the BT routers are crap, sometimes the Burouters easier to configure from the MDC, it also gives you more config options trying going to its address forward slash MDC so http://192.168.1.254/mdc in your situation. See if somethings turned on there if not, maybe a router reset is in order. Have you tried accessing Oracle from a web based proxy?
Message Edited by Kirok on 13-08-2008 06:06 PM
loupblanc
Member
I'd forgotten about mdc. That said, I really can't find any settings in there which could suggest anything dodgy blocking ... or rather filtering I should say, access to oracle.com. There's nothing explicit on there anyway that I can see.
I can access it via a web based proxy, yes (I wasn't even aware such sites existed, thanks for the tip). Anonasurf isn't the best thing to use to access the website but it's something.
Kirok
Master User
You running any domain or extra functionality on SBS or just email, I mean that shouldn't influence the Linux LiveCDs you've tried but still worth a look?
From what you've said I'm inclined to believe the common element is the router, unless a common configuration has been applied to each computer but the LiveCDs have eliminated that. Check the DMZ as I've said below just to make sure nothings in it
I'd try a complete reset of the router just to eliminate anything at that end, if you've got a spare try that. Failing that go to the firewall and turn off options to test (start with the more esoteric) check to make sure nothings in the DMZ, Access restrictions are usually done for each individual device from the LAN tab so its odd that it would be turned on for all but worth a check.
I mean has it always been like this, have you recently moved sites, has a former employee just left?
This is a complete non-sequitor but if the recent testing has been all from the usual windows machines its worth a try from the command line do a
netsh winsock reset
netsh int ip reset all
and then restart, I don't suspect it will work but like I said worth a try. Another option and I'm really going out on one here is to monitor the connection with something like http://www.wireshark.org
croxlea
Member
I have sorted it now, thank you.
Kirok
Master User
Apologies, I'll imagine you're getting update emails; threads been hijacked now so just ignore them or turn them off.
