Unable to manipulate text/pictures on the eshop homepage
thoseoldrecords
Member
Hi, for the past two weeks I have been unable to change the colour of text on the homepage. In addition, the ability to change the size and location of pictures on the homepage has gone. Very frustrating as my site is updated daily. There used to be a display over products displayed on the homepage but that has gone as well. Is anyone else getting this? Chris - Those Old Records
1 ACCEPTED SOLUTION
Accepted Solutions
graemewilliams
Super User
Hello thoseoldrecords
I assume you are using the built-in text editor to make the changes you have mentioned? Correct me if this assumption is wrong. I've never been a big fan of this text editor. I've found it to be fiddly and often gives unpredictable results. As a first step I suggest you try using a different web browser. I usually work with Firefox. If that doesn't work then I'll try Chrome and then Internet Explorer (even though it is not recommended by ePages). In the past I've been able to fix stuff in Internet Explorer which I couldn't do in other browsers.
www.rikkismusic.com
www.epagesdesign.wordpress.com - Tutorials, Tips & Ideas on ePages Ecommerce software.
View solution in original post
1 REPLY 1
graemewilliams
Super User
www.rikkismusic.com
