Upgrade to Infinity but keep existing Business Hub?
mfirth
Member
Hi,
We're about to upgrade from DSL to Infinity, and I think BT are going to be sending us a new Business Hub 3.
However, we already have the 2701HGV-C hub, which I think was originally supplied with Infinity installations.
Would it be possible to continue using this existing hub?
This will save having to spend time reconfiguring the new Business Hub 3 with the firewall and IP address settings we need (which are already configured and working on the old hub)
Other sites on the Internet seem to suggest the Business Hub 3 is basically the same hardware as the "Home Hub 3A", which doesn't have a great reputation - is that correct?
Michael
2 REPLIES 2
MHC
Guru
Yes, you can continue with the 2701 - just feed the modem output into the WAN/Fibre socket.    It is detailed in the 2701 documentation.
Yes, the BH3 is a reworked Residential Hub.
mithcd
Power User
Thanks for the clarification. Good luck to you mfirth.
