Upgrade your BT broadband Yes! You can upgrade to superfast BT Infinity FIBRE BROADBAND.
BML
Member
Not only am I as tight as a fishes posterior but I am an innately suspicious when something looks good especially when I read that the speeds promised are rarely reached.  But the question from an untechnical person even though I constanly use the Internet, is.  “Does the move make sense?
1 ACCEPTED SOLUTION
Accepted Solutions
spank
Grand Guru
Hi there,
Depends on what you use the internet for I suppose.  If you stream, download, plan on using voip phones, use cloud backup then I suppose the answer would be go ahead and upgrade.
If you surf the net and use it for emails then you don't really have much of a reason.
Eventually it will all be fibre anyway so you would just be delaying the innevitable.
View solution in original post
2 REPLIES 2
spank
Grand Guru
Hi there,
BML
Member
Makes sense to me.  Many thanks.
