VPN Passthrough
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Currently have a BT Infinity hub and i'm trying to enable VPN passthrough. Does anyone have any idea whereabouts in the settings of the hub this option is lurking??
0
Kudos
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi andyb66,
With the BT router/hub, what you will need to do is setup the port forwarding in the router. You will need to know what ports your VPN device uses, and open these ports and point them to the VPN using the router.
For the 2wire router (2700 and 2701) here is the port forwarding guide
For the Busness hub 3 here is the port forwarding guide
For the new hub 5 here is the port forwarding guide
I hope this helps
Mark
0
Kudos
