Can anyone advise what ports need to be opened for BT VoIP?
I'm 100% of calls dropped, atleast 20-25seconds into the conversation, so doing what I can to clear this up.
Cheers,
Tom
Solved! Go to Solution.
BBV Incoming Port Ranges (all UDP) - 32000 to 36000 & 2727 & 5060 & 49152 to 49193
Do these use the "SIP-based Internet telephony" Application Type?
If it's the Business Hub you're using, SIP-ALG is enabled by default.
