- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Since BT uses Vodafone's mobil infrastructure, what are the chances that the much hyped femtocell Access Gateway will work with BT business mobile handsets?
Like many subscribers, I live in an area where I have to go upstairs and lean out of the window to send texts, and a conversation would verge on the suicidal! Although expensive, the broadband-enabled booster could be the answer to many of my problems.
John
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi PigzleFly,
The Vodafone product is solely a consumer based product.
Priced in several options:
a) New subscribers: Low tier handset + femtocell + some minutes/texts @ £15/month
b) High end handset (an HTC smartphone similar to Google Android) + femtocell + 600 minutes @ £30/month
c) Rental only at £5/month
d) One off payment of £160
There are no special rates or extra minutes for use via the femtocell.
Access is controlled through a "whitelist" which can be updated online or via customer care, so any Vodafone 3G subscriber could use the femtocell, but only those phone numbers programmed/entered on the whitelist will be allowed to.
In principle our SIMs would/should be able to work with these units, however, as numbers must be added to the whitelist first, no doubt this will be crossed checked against Vodafone number database and would refuse connectivity.
Hope this helps
Tracey
BT Forum Moderator
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi PigzleFly,
Hope this helps
Tracey
BT Forum Moderator
