Has anyone had any experience with this problem. We are using the VoiP service with our IP PBX.
We can dial out and receive calls however the BT server sends a reinvite every 30 seconds which casuses the audio to blip for a split second. I have tried this with 2 phones directly, a soft phone and two IP PBX and the problem is always the same. We use the PBX with other providers without a problem.
Having spoken to VoiP help they tell me this is the way it is and it my equipment that is at fault. Although they can not tell me why its my equipment or suggest any equipment other than their own that works.
The problem is, as I see it, once the call is established there should not be invites uless the call changes, ie a transfer is made or the call is put on hold, so along as the BT server keeps sending reinvites every 30 seconds the audio is bound to blip every 30 seconds and no changes to my settings will make any difference.
While the service can not be called unusable it is far from satisfactory, has anyone experinced this problem, may be on an Asterisks server or other non BT software. Any ideas or solution would be welcome.
