Will the BT Business Hub 3 connect to a Draytek AP800?
artworkings
Member
Hi I am trying to extend my network wirelessly using the AP800 - it worked fine with the Draytek2710 router but I can get the AP800 to connect but it will not work correctly. (2710 died!)
Scenario, device plugged into AP800. The hub3 see the AP800, but it will not issue an IP address to the device plugged in the AP800.
Am I wasting ny time here or is there a way??????
1 REPLY 1
whiller123
Super User
Hi
it should work OK I have Netgear AP's on BH3's & they are fine. I am not familiar with the AP800 to be honest but make sure it has DHCP turned off (if it has it) & let the BH3 handle DHCP.
Rob
