Wireless Printers keep disconnecting from the wireless network
Russell
Member
Hi
I have just installed BT Broadband on a business line and we have 2 printers connected to the network wirelessly
One is a HP Colour Laserjet and the other is a HP Multifunction Inkjet, both of which are less than a year old.
They connect fine using WPS, but cant seem to hold onto the wireless signals.
Any ideas?
3 REPLIES 3
DaveA
BT Partner
BT Partner
Hi,
Do they both lose the wireless signal at the same time?  If they do then you might consider changing the wireless channel, as it could be external interference.
Dave
iptables101
Power User
You can check the range here too. For testing purposes, try placing the printers next to the router and see if it makes a difference.
Also try channels 1, 6 and 11 and see which one is better.
orthohin
Grand Master
In this case you can add a extra access point for better signal.
________
Orthohin
