broadband office
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
I have received and set up my wireless business hub,which is working fine. Can you tell me the range of signal and if needed is there any way to boost it for reception at say 50metres. I have no telephone connection in a separate nearby building. I look forward to your response.
Peter Withers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Not sure on the range.
the signal can be "strengthened" by changing the wirelss channel used.
by default it is set to auto which i have found to be flakey. i have found channel 6 or 7 to work pretty good.
the range depends mainly on environmental factors such as thick walls, bodies of water, radio interferance, electrical wiring within the walls, the surface the router is sitting on (believe it or not carpet can play havoc with the signal due to static) and a whole load of other things.
