- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
my bt business hub 2700hgv firmware version is v6.1.1.22. i done some research on the internet and found that v6.1.1.48 is the latest version how do i upgrade to that version ? because this firmware not letting me change devices name and portforward properly.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I have just had confirmation that the router is now on version 6.1.1.48.1.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
Can you please private mail me the seriel number of the router so our technical team can try to manually update the firmware.
Kind Regards
Fiona
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I have spoken to the technical team about this. They can manually update the firmware of the router for you, however, the new firmware locks the router to the domain.
The BT Business hub is suplied for the Business broadband connection and the new firmware locks the router to the Business broadband domain details. The residential Hub, for the residential line is the same and the firmware will lock the router to the residential domain.
So basically, if we get the technical team to manually update the router firmware it could stop you being able to use the router on your residential connection.
If you would like us to go ahead with the firmware update, please let me know.
Kind Regards
Fiona
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
yes you can go ahead with the update because it will work am certain thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I've asked them them to put through the firmware upgrade manually for you.
Kind Regards
Fiona
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks i will accept this as solve once the upgrade is taking place thanks. 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
Kind Regards
Fiona
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thank you yes it on the latest firmware now my sync speed went up abit. thanks fiona really appreciate it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hi,
I'm using 2wire 2701hgv-w,can you give me bt firmware (version 6.1.1.48.1)?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Is this really true? You have to request somebody at BT update your firmware remotely?
Surely not!?
