change name servers on domain name?
AlanMurray
Member
How do you change the name servers on a domain name. I only have a login for https://www.btdomainsaccount.com/ and there appears to be no ability to change the name servers. Don’t understand the Zone configuration part either. Never had this on any another domain
1 REPLY 1
markp
Grand Guru
Hi,
If you have a login ID for https://www.btdomainsaccount.com, but you are having problems you can email [email protected] to ask them to make the changes to the domain name DNS.
I hope this helps
Mark
