- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
We are currently having a new VoIP system installed.
They are fitting a new line so I am trying to pre-set everything prior to the line going live.
I am having problem trying to change the extension numbers on the selfcare site, plase can you inform me how to change the extension numbers on all the internal voIP numbers?
Any help would be much appreciated
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Flueolgist
You can not change the extentions.
You can however create other codes.
Broadband voice
Log into webcare www.bt.com/businessbbv/webcare and go to Making call - Speed Calling and you can setup your own codes for any number.
Hosted Voip
Log into webcare with your admin number then go to short codes and click the add short code tab.
Hope this helps
SC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Flueolgist
Broadband voice
Hosted Voip
Hope this helps
SC
