There is currently a known issue with the Mac software that ships on the E170 that prevents it from working correctly with OSX 10.6 (Snow Leopard). BT is working with the manufacturer in order to provide updated software that works with OSX 10.6 (Snow Leopard). I expect this to be made available in the next 4-6 weeks.
In the meantime there are workarounds available in order to get the E170 to work with Snow Leopard, but these are not supported by BT. I can provide more information on these if you wish.
Tim
There are two seperate workarounds depending on whether you installed BT Access Manager on OS X 10.5 (Leopard) and upgraded to 10.6 or are installing on OS X 10.6 (Snow Leopard).
Workaround for AM users who upgraded to Mac OSX 10.7
Workaround for installing AM on Mac OSX 10.6
The workarounds allow you to use the E170 without the BT Access Manager software and should be considered a tempoary solution until an updated version of the BT software is released.
Tim
Hi Naishy
I wonder if you coudl help me, I have tried follwoing your work around, but my device dosent even show up in my network options.
Is there anything I can do to sort this out ?
best Regards
Mark
Hi Mark,
Which workaround were you using - the upgrade or the fresh install?
We hope to have a new OSX 10.6 compatible BT Access Manager available in the next couple of weeks.
Tim
Rex,
Glad to hear you've had some success with Snow Leopard. Those settings are covered in the work arounds listed on this thread. A new version of BT Access Manager that is compatible with Snow Leopard should be available in the next week or so.
Regards
Tim
Hi Tim
I was using the fresh install workaround.
best regards
Mark
