losing broadband
michael_d
Member
we also have been having lots of problems with broadband dropping out and having to reset the connection.
It doesn't always reconnect when I try to reset it! I often have to wait for it to come on itself or keep trying until it works!
It is significant that other computers may have broadband and not lose their connections!  But the problem occurs even if I am the only person on the network.
 Worst times are 8-10 in the morning and 7-9 in the evenings. For a lot of the time there are no problems but it does seem to be an unreliable system! This is a daily problem and has been an issue since we upgraded(!) the broadband.
I would guess, not based on knowledge, that the router is possibly faulty and cannot manage the connections/traffic.
Any help would be appreciated
michael
1 ACCEPTED SOLUTION
Accepted Solutions
JohnE
Guru
Michael, please don't waste your time with the log file.  I'd recommend that you Contact Us
View solution in original post
3 REPLIES 3
JohnE
Guru
Sorry to hear that you are having difficulty with a dropping connection, michael_d.  Please see my post here:
BB Connection dropping out
michael_d
Member
Hi JohnE
Thanks for the reply. I reckon that we fulfil the requirements from the link you gave.
We had ordinary broadband for several years before switch and had some problems but nothing like we have now!
How do i access the log file?
Michael
JohnE
Guru
