office 365 e-mail
Robin12
Member
I have just been informed that my e-mail  is about to change with BT, I am concerned that this is going to disrupt my business. I have several e-mail accounts running through the main bt e-mail account. am I going to have to reset all of the accounts to continue sending and recieving e-mails, and then there is the forwarding to my blackberry torch. perhaps someone can direct me to the right information to set this up so that I do not lose any business. thanks
1 ACCEPTED SOLUTION
Accepted Solutions
DaveA
BT Partner
BT Partner
Hi,
First thing you should do is log in to webmail and move/delete the email that won't download.  It's likely to have become stuck for some reason, so make a copy of it from webmail and get rid of it.  That should stop the issue with Outlook.
Let us know how you get on.
Dave
View solution in original post
5 REPLIES 5
tidaltides
Power User
Do a follow up from time to time to have them check it regularly.
Robin12
Member
now there is a problem with the e-mails on outlook 2007. when i first open up outlook, the e-mails start to download, gets to the last one and cannot finish downloading, and will not send any e-mails at all. i am having to rely on my blackberry to do all of my replies. no response from BT, and I get theimpression that nobody is interested. has anybody got any ideas. thanks
DaveA
BT Partner
BT Partner
Hi,
Dave
Robin12
Member
Dave,
after i posted on the forum, i decided to go through my webmail and check the account, deleted a few e-mails, and tonight outlook seems to be fuctioning ok. many thanks for the reply, if i have any other issues, i will post them .
regards
Robin
DaveA
BT Partner
BT Partner
Hi Robin,
No problem.  Glad to help.
Dave
