register.com
yusaini
Member
Hello ..
I have 4 domain names registered with BT.  I was given the www.bt,com/domains/admin to manage those domain names. Lately I have issues with the doman names and I just recently found out that that they are now maintained by register.com. I have tried to speak with BT support but they can't help me and I ended up calling register.com directly. Is there a management portal from bt to administer those domains. By the way www.bt,com/domains/admin is not working, can't even change the account details ... I am stuck here ... any help will be appreciated .. Thanks
1 REPLY 1
Plumly
Grand Master
Hi Yusaini,
If you try
https://www.btdomainsaccount.com/
click onto Login and see if that allows you access
thanks
pLumly
