remove an old website
hb
Member
please could a kind soul explain how I remove (unpublish) a bt website that I don't want to use any more as the business is no longer active?
many thanks
H
1 ACCEPTED SOLUTION
Accepted Solutions
Cantoris
Power User
If you still have access to the webspace, start up FTP and delete the files from the /public/ folder, including any subfolders.
If you don't have access, contact support and ask them to do it.
Is that the sort of explanation you wanted or do you need more step-by-step?
  Nigel.
View solution in original post
2 REPLIES 2
Cantoris
Power User
  Nigel.
Nguitar
BT Partner
BT Partner
If you want to keep the site files intact you can also enter your public folder and simply rename your index file to something else
