trying purchase private ssl certificate but error
fonejackerni
Member
Hi, i was trying to purchase a private ssl certificate for our website but each time i try i keep getting this error
ERR: Could not create Certificate Signing Request (CSR)
Is there a problem with the server or am i going to have ring to have this purchased and installed? i do have a free one installed does this have to be taken out before the request can continue? any help would be much appreciated.
Thanks in advance
B.R
1 ACCEPTED SOLUTION
Accepted Solutions
Ian1974
Moderator
Moderator
Hi,
Currently there is an issue generating the CSR via the BT Website.
In this case, please use the dns enquiry form at www.dnsforms.co.uk and we will generate one on your behalf.
Please include the following.
  • Full name
  • Company name
  • Address
  • Contact number
  • Email address
  • Domain name
Regards,
Ian - F -
View solution in original post
5 REPLIES 5
tetrapackage
Power User
Try to remove the free version and have this one installed. You can also contact BT for assistance.
fonejackerni
Member
Hi, thanks for the reply, thought the free one might cause this. Can't see a way to remove it there is no option to, that I can find, the ssl module has changed since i used it last, I think il contact support on the phone this is something I can't sort out myself I think. Can you give me a number for northern Ireland to ring? Thanks again
Kind regards
Ian1974
Moderator
Moderator
Hi,
  • Full name
  • Company name
  • Address
  • Contact number
  • Email address
  • Domain name
Regards,
Ian - F -
fonejackerni
Member
Hi, Ian1974
                Thanks for the advice, i only just noticed your reply i have put all the details in the enquiry form, and a brief explanation why i can't get it done so here's hoping it gets sorted, Thanks again.
Kind Regards
Ryan
abirhasan
Master User
I think you are missing some things. Please do it correctly. That may help..
___________
abirhasan
