Hi, i was trying to purchase a private ssl certificate for our website but each time i try i keep getting this error
ERR: Could not create Certificate Signing Request (CSR)
Is there a problem with the server or am i going to have ring to have this purchased and installed? i do have a free one installed does this have to be taken out before the request can continue? any help would be much appreciated.
Thanks in advance
B.R
Solved! Go to Solution.
Hi,
Currently there is an issue generating the CSR via the BT Website.
In this case, please use the dns enquiry form at www.dnsforms.co.uk and we will generate one on your behalf.
Please include the following.
Regards,
Ian - F -
Try to remove the free version and have this one installed. You can also contact BT for assistance.
Hi,
Regards,
Ian - F -
Hi, Ian1974
Thanks for the advice, i only just noticed your reply i have put all the details in the enquiry form, and a brief explanation why i can't get it done so here's hoping it gets sorted, Thanks again.
Kind Regards
Ryan
I think you are missing some things. Please do it correctly. That may help..
___________
