unable to get broadband access using via Cisco 857 ISR
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
Having tried the BT supplied 2 Wire ADSL Router and not getting on all that well with it, I've been trying to configure my BT Business Broadband to work with a Cisco 857 Integrated Service Router - the one without the WiFi if it matters. The BT service is the one with the 8 static IP addresses.
With the config listed below the router comes up and the CD and PPP lights come on, I can even ping a well known address (212.58.246.94 - a bbc server), and although the first ping always fails pings 2-4 get responded to (rather odd I thought) - this is pinging from the PC being used to configure the router.
But I can't browse to any named websites using DNS, or entering an IP address.
Here's the config. Any thoughts appreciated. Thanks Geoff.
show config
Using 4232 out of 131072 bytes
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-3429188023
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3429188023
revocation-check none
rsakeypair TP-self-signed-3429188023
crypto pki certificate chain TP-self-signed-3429188023
certificate self-signed 01 nvram:IOS-Self-Sig#7.cer
dot11 syslog
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip cef
ip domain name yourdomain.com
ip name-server 194.72.9.34
ip name-server 194.72.0.98
username **** privilege 15 secret 5 $1$UOsN$pdeMNm4xK9Lkl56jMMSHU/
archive
log config
hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description $ES_WAN$
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip address 217.37.***.** 255.255.255.248
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname *******@hg43.btclick.com
ppp chap password 0 ********
ppp pap sent-username *******@hg43.btclick.com password 0 ********
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 100 interface Dialer0 overload
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 100 remark CCP_ACL Category=2
access-list 100 permit ip 10.10.10.0 0.0.0.7 any
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
