uploading sitemap
jono_10
Member
hi guys sirry if this is a total noob question but im very new to easysitewizard and the world of creating websites.
1st one how do i upload my sitemap to my "/public" drectory?
2nd is there any way you can upload images with a transparent background, in my case i have cut a cherry picker out on photoshop, saved it as .png .tiff (or .giff i forget) and a jpeg and they all automatically fill in the surroundings with a block colour, i expect this from a jpeg and a png but the tiff or giff saves as only the image... any ideas?
appologies if i sound simple but as said im very new to this,
regards jono
1 REPLY 1
BLWRAVE
BT Partner
BT Partner
Hello If you are using the easysitewizard you would just use the "publish" bottom , if you are uploading a site that you created outside the platform, we use a FTP client called filezilla and just drag the content from you home computer to our servers. If you want to use a back ground picture, if again you are using your own coding it would be in the coding. If you are using the Template from easysitewizard you would have to change the coding to have your picture as the background
