Have Hub set up to connect to HP printer for WiFi printing.
Been using OK with a Windoze PC
Now moved o a MAC .....
Having problems getting MAC to connect for printing ......
HP are asking me to check - Does the BusHub 5 support Bonjour
Hi Argonaut
I have taken a look into this and have discovered that there were reports of issues with Bonjour and the Hub 5 a few years ago. I would have assumed these issues would have been eradicated following various firmware updates, so I would recommend making sure your firmware is up to date on the router.
If that does not resolve the issue it may be a case where you need to try the BT SmartHub or even a third party router, but I would hope that you could get it working on the Hub 5 itself. I will speak to a few agents in our 2nd line teams for you in the coming days to see what information I can dig up also.
Regards
Ryan
Hi Argonaut
Regards
Ryan
Thank you for posting something like this
